99 windstar a/c
Old Apr 12, 2007 | 11:47 PM
richg9781's Avatar
Default 99 windstar a/c
the a/c heater will only blow out the defrost by the front windsheld. i have never had the happen before.is it somthing simple or should i take it in
Old Apr 17, 2007 | 10:57 PM
GallagherPreach's Avatar
Default RE: 99 windstar a/c
When you say it will only blow out the defrost do you mean no air comes out anywhere else?
This may be a simple switch problem located on the **** itself.
Old Apr 23, 2007 | 03:50 PM
Use Common Sense's Avatar
Does the damper move to other positions like vent or floor? If not, start looking for a vaccum leak in the vaccum operated damper system. Zcould be just a line that got knocked loose under the dash. Also check the hard line under the hood and the vaccum canister.
ranshells
Jan 14, 2011 11:13 AM
