Liftgate Support Device - Broken Ball Joint
Old Jan 1, 2007 | 01:00 PM
KREEKVIEW's Avatar
Default Liftgate Support Device - Broken Ball Joint
I have a 2000 Windstar LX. The ball joint that is spot welded to the side of the liftgate where the liftgate support device (strut, support arm) attaches has rusted and broke off. I have found other posts that mention this same problem on other Ford vehicles so I am guessing there is a solution / repair.....but what is it? Can I just buy the ball joint and install it myself? Do I drill out the old weld and install a bolt-on ball joint? Does the bracket have to be replaced? Any suggestions would be appreciated. Thanks.
Old Jan 1, 2007 | 11:41 PM
wheelsup68's Avatar
Default RE: Liftgate Support Device - Broken Ball Joint
Go to parts store and see what equipment comes with new lift support, it may come with all you need to install?
Old Jan 2, 2007 | 10:21 AM
KREEKVIEW's Avatar
I have replaced a lift support in the past, it is just the support, nothing else comes with it. The ball joint is spot welded on a bracket that is welded to the liftgate. In my research, I read where there was a problem with brackets bending on the 90's Explorer's and one other posting on broken ball joint. I might end up having to be creative! Thanks for the response.
sbcadillac
Apr 11, 2008 11:49 AM
frankd
Mar 21, 2008 01:03 PM
bmarnall
Jun 28, 2007 08:23 PM
64compact
Nov 2, 2005 08:16 AM
DYI
Mar 28, 2005 11:54 PM
