The Old guy
Old Apr 7, 2012 | 02:00 PM
The Old Guy's Avatar
Default The Old guy
On my '95 Aerostar the tail lights go off when the headlights are turned on! Anyone know the cure? Thanks
Old Apr 7, 2012 | 03:51 PM
Can't say for sure if this is the cure.
The headlights consume a fairly large amount of current to operate. To have a complete circuit to operate , the headlights have to have a good ground . I would suspect that the ground for the headlights is non-functional and therefore it is using the circuit for the tail lights to get it's ground. The cure very possibly might be to provide a direct wire to the headlights for their ground or just go and look for,clean and tighten all the ground connections you can find that come from the negative battery terminal to the various sheet metal points. One of them is either faulty or disconnected. If you do this when the headlights are on , you will know which one it was as soon as the tail lights come back on. You will be surprised when you find it!!
Mo Junk
Jul 13, 2020 03:49 AM
red62gal
Sep 7, 2010 08:11 PM
oldcarmechanic
Jan 11, 2009 10:37 AM
warpwr
Sep 19, 2007 10:14 AM
tlranger69
Aug 1, 2006 12:04 PM
