POST TECH QUESTIONS IN THE PROPER AREAS > > >
Old Aug 9, 2005 | 03:22 PM
Guest
Guest
Posts: n/a
Default POST TECH QUESTIONS IN THE PROPER AREAS > > >
This section is for welcoming new members only.
If you have a techinical question, please post it in the General Tech or in the proper section for the car you have a question for. Thanks so much!!
~Amanda
Old Jun 13, 2011 | 11:41 AM
TEKE's Avatar
where can i buy a water pump pulley for a 95 ford aerostar 3.0 engine online?
Old Sep 7, 2011 | 12:38 PM
dona's Avatar
I have a 95 windstar. I have a clicking sound that sounds like a short that is coming from my fuse box. When this happens the driver window goes down the wipers come on without turning them on and the locks try to lock. what causes this
Old Sep 7, 2011 | 12:39 PM
dona's Avatar
[quote=dona;64854]I have a 95 windstar. I have a clicking sound that sounds like a short that is coming from my fuse box. When this happens the driver window goes down and the windshield wipers come on without turning them on and the locks try to lock, and you can't turn them off.
Old Sep 7, 2011 | 03:44 PM
Amanda, You're OK!!
Thanks for keeping tabs on us .
Old Sep 16, 2011 | 11:58 PM
j0o05s53e3's Avatar
Hi i have a problem with an Aerostar 87 the shift lever is broken and it has been really hard to find a replacement. The thing is that it is a manual transmission. The problem is that Ford does not have replacement part for that year and model. If anyone knows if any other shift lever can work for this aerostar that can be install to work properly or if you know where one can be found please reply. This post is probably a little off topic but I really need help! please reply! Thanks!
Old Sep 18, 2011 | 04:36 PM
Is this with a column shift or a floor shift?
Exactly where is it broken ?
Is it a place where it can be removed and brazed or welded?
You may need to do one of these measures if you can't find a replacement.
Old May 2, 2012 | 10:36 AM
ProfJim's Avatar
How do I replace the vcr in my Ford 2003 Windstar with a dvd player? Thanks
harmission
Jun 21, 2024 05:19 PM
Aug 9, 2005 03:22 PM
