Reverse lights
To clean the bores those pins slide in ,you might use a cloth wrapped around a screwdriver and really get all the unwanted stuff out of there.
There is a special caliper pin grease that has a high melting point ,is not harmful to the rubber boots and that should be used to lube them on assembly.
That area is subject to all kinds of road grit and cleanliness does pay off in the long run.
