Throw Code...
Old Jun 21, 2014 | 12:23 PM
MortTheBeast's Avatar
Default Throw Code...
What can I do or unplug that would 100% throw a code? I have a feeling something is up with my computer and wanted to test it and see if the check engine will come on.
Old Jun 21, 2014 | 07:06 PM
bluewind's Avatar
Try the MAF sensor. Make sure the engine is warm.
You could also remove a vacuum hose and see if you get a lean code.
You could pull an ignition wire off 1 spark plug and you should get a misfire code.
Old Jun 21, 2014 | 08:05 PM
sk1nner's Avatar
oxygen sensor should do it too
maineman
Aug 11, 2018 08:23 PM
cwildkats
Dec 27, 2012 09:59 AM
