Ford Contour While only built on a short time span, the Contour was very popular with people of all driving styles, from the base model making for a great family car, to the SVT making a great track toy.
1999 ford contour fuel problems
Old May 22, 2012 | 08:30 PM
jsmith41010's Avatar
Default 1999 ford contour fuel problems
my 99 ford contour ran out of gas and now it won't start. put fuel in, the fuel pump is working. they car started at first but when i would push down on the gas it would bog out and die, now the car won't start at all. we tried spraying carb cleaner into the engine, that seemed like it was gonna work, but it didn't. we even took the fuel filter off and tried to clean it out. any ideas??????
Old May 23, 2012 | 07:14 AM
Sometimes the fuel injectors can get air bound and cannot inject air.
Keep trying and make sure you are getting fuel up to the engine past the filter that may look good but still be clogged enough to prevent fuel from getting up to the engine.
Old May 23, 2012 | 08:06 AM
that's my next step. buying a fuel filter and go from there. we tried for a few hours to get it to start. now the battery is almost dead.
Old May 23, 2012 | 03:50 PM
bluewind's Avatar
There is a strainer at the intake of the fuel pump. If there was dirt in the tank when it ran out of gas it may have clogged the strainer.
Do not over-use the starter. You risk overheating and killing it. You can try 3 x for a few seconds then you need to let it cool off for maybe an hour.
cdog0809
May 20, 2011 08:43 AM
orechia
Dec 30, 2010 06:04 PM
mikegigabyte
Jul 4, 2009 09:30 PM
kdbailey
Sep 29, 2008 08:20 PM
95se_mexican
Dec 16, 2006 06:52 PM
