1983 LTD crown vic idle too high
Old 07-01-2016, 12:16 AM
Radu Georgescu's Avatar
Default 1983 LTD crown vic idle too high
hi
bought today this 83 crown victoria and the idling appears to be high.
is there any adjustment to it? such as an idle control valve? I do not hear any vacuum leaks.
is there any DIY troubleshooting guide?
I have experience with fuel injection but not with this model
Thanks!
Old 07-01-2016, 12:31 AM
I also have some problems with the fuel level. What is the spec (ohms at Low / Full) for the fuel level sending unit and where can I find it?
Old 07-01-2016, 06:15 AM
Use Common Sense's Avatar
Does it have the 5.0L w/CFI or 5.8L w/CARB engine?
Old 07-01-2016, 02:27 PM
here is a picture.
which one would this engine be?
Old 07-01-2016, 04:37 PM
Hope you guys don't mind , but I think I see a throttle control piece and It does appear to be with a carburetor. I could be wrong !
Old 07-05-2016, 03:51 AM
A picture without the air cleaner on the intake would be more useful to easily identify what you have.
Hanky is right, the throttle control piece appears to be for a carb so the idle should be adjustable.
Here's a picture of a CFI unit...
Old 07-26-2016, 07:31 PM
My engine is 5.0 fuel injected. And the cause for the too high idle was the throttle wasn't closing properly. Either dirty or the spring got too weak. Push it back with the hand and it idles correctly. So not a big problem!
87Mojo
06-04-2019 05:41 PM
One to Remember
05-20-2013 11:26 PM
dinkydow3
12-16-2012 09:45 AM
87crownvic
03-16-2010 02:00 PM
cardinal33
01-15-2008 08:34 PM
Quick Reply: 1983 LTD crown vic idle too high
