2012 Escape Sync won't recognize any Aux Inputs
Old 04-12-2015, 12:45 PM
rwoods's Avatar
Default 2012 Escape Sync won't recognize any Aux Inputs
I've only had the vehicle a month or so. Everything worked fine. I had bought a Flash Drive, uploaded all my music on it and was playing it using the Sync system until,,, my friend went to charge his IPhone in my USB. I took out my flash drive, he plugged in his phone to charge but he said his phone wasn't charging. After that,, both my auxiliary ports aren't being recognized so I can't play my music in either my USB or my Line In ports.
I tried the pulling the fuse method and the disconnecting the negative cable on the battery method but none of them worked. Anyone have any advice for me as to how to fix this issue.
Rick
Old 07-10-2015, 06:44 AM
EmmaJean500's Avatar
Default There was an update a couple of months ago
Go to syncmyride if I remember correctly. The site will ask you for the VIN. By this date you may have fixed the problem. I need to recheck my 12 Escape also. Hope this helps.
Old 07-13-2015, 03:15 PM
Darrell85's Avatar
did the adapter burn up port where it lugs in or it may have a bad connection
Fordhamjc
05-18-2015 08:53 PM
londi430
09-08-2013 10:31 AM
nicklavoie
01-17-2013 07:18 AM
felixcardona
10-28-2012 02:09 PM
dkimbro
06-29-2005 02:15 PM
Quick Reply: 2012 Escape Sync won't recognize any Aux Inputs
