5.4 almost stalling issue
Old 04-01-2016, 10:03 AM
mxer201's Avatar
Default 5.4 almost stalling issue
My 01 Navigator 5.4 with 183k miles has an issue with "almost" stalling. After heavy braking then immediately pressing the accelerator, the tach will sometimes drop to 200 or 300 then back up above 1k and runs fine. For example, traveling at 55 to 60 mph, start braking to make a 90 degree right turn. Let off the brakes and press the accelerator while turning and the near stall occurs. I can almost predict when it will happen. Already replaced the IAC and recently a new fuel pump that failed. Considering replacing the vacuum rubber connectors, elbows, etc. as my next step. I'm thinking vacuum leak. Suggestions or ideas? I'm sure this issue has been thoroughly discussed, didn't have time to find the post.
Old 04-15-2016, 02:41 PM
Alanah_Rae's Avatar
Welcome on a board !!
Old 04-15-2016, 03:44 PM
Does this happen every time you depress the brake pedal?
focusowner2001
08-04-2007 05:07 AM
fcescape
10-25-2006 12:00 AM
fcescape
10-24-2006 05:47 PM
fcescape
West
10-24-2006 04:07 AM
grizzly
01-30-2006 08:26 PM
Quick Reply: 5.4 almost stalling issue
