Heater Level Stuck on Hot
Old 03-06-2010, 05:42 PM
Ejectr's Avatar
Default Heater Level Stuck on Hot
My wife's 2002 Explorer heater temp seems to be stuck on high. When the engine is running, turning the heater temperature adjust **** from high to low doesn't seem to change the temp or if it is, it is very minimal. It blows maximum hot and turning it all the way cold changes it very little. Seems like a little temp change moving the temp control **** from max heat back to 1 o'clock position. Can also hear movement...not clicking.
Wonder if I have a broken actuator gear or broken blend door. Seems the door wouldn't move at all if the axle was broken. With the slight temp change moving the ****, I'm thinking maybe the actualtor gear has broken a couple teeth amd jamming.
Thanks.
walter5623
12-03-2015 10:42 PM
makuloco2000
05-26-2014 11:16 PM
SAMF
04-30-2010 12:07 PM
gnorman
03-30-2006 11:41 AM
mustangsidewinder
01-23-2006 03:37 PM
Quick Reply: Heater Level Stuck on Hot
