Help!Driver side door problems!
Old 11-20-2007, 12:18 PM
offroad1's Avatar
Default Help!Driver side door problems!
Okay I have a problem with my driver side door.The problem is that it will not open from the outside but from the inside.Would anyone have any idea on how to remedy the problem?If it helps for you to give me a diagnosis I would put the key in the lock and it would turn like its goin to unlock the door but its not catching on the mechanism to unlock the door.You can hear it trying to unlock(it will unlock all the other doors)but it just refuses to unlock the driver side!So if anyone could help me out I would greatly appreciate it,Thanks in advance.
Old 11-21-2007, 09:31 AM
Default RE: Help!Driver side door problems!
its the lock itself replace it
Old 12-23-2007, 12:03 PM
offroad1's Avatar
Where would I be able to find a replacement lock for it?
Old 12-26-2007, 08:53 AM
oldtimer35's Avatar
I know it's been a while since you posted, but if you haven't fixed it yet, you might just have a broken or detached rod. There is a clip that holds the lock rod to the key tumber. If the key turns and you can hear something moving, it sounds like the rod became detached. It just slips back into the clip. If the ear on the clip is broken, then yu will have to replace it. Your local ford house will have the part.
jackiel
09-18-2014 06:11 PM
andybarrn
04-03-2013 09:04 AM
Ranger96
06-07-2007 12:00 AM
chaud
07-22-2006 01:55 AM
Quick Reply: Help!Driver side door problems!
