not enough power when step on gas
Old 11-03-2008, 06:34 AM
raj828's Avatar
Default not enough power when step on gas
i have an '04 explorer ltd, the first problem i had is when i start the truck in the morning, it turned over. then you need to step on the gas to start it... (problem might be on the IAC). then i notice lately when i tried to step on the gas (stationary) the rpm would not rise to 5, it would just barely reach 4 then goes down even when i haven't released the gas yet? what is wrong with my truck... anybody have ideas?
thanks...
Old 11-04-2008, 04:32 PM
oldtimer35's Avatar
Default RE: not enough power when step on gas
First problem does sound like the IAC, so either replace it or clean it. Second problem, does it run alright when you are driving it? Is this only when setting still in neutral? These computors have a failsafe system built in to them. They will not let you "redline" the engine in neutral. They do a fuel cut to avoid high rpms and the engine sounds like it is trying to die.
Alaska57
02-13-2014 08:13 PM
dgforeman
12-08-2010 11:12 AM
93f250xlt4x4
09-16-2006 03:42 AM
Quick Reply: not enough power when step on gas
