Sponsored by:
Sponsored by:
Power window motor
Old 05-20-2011, 08:44 AM
fordman7's Avatar
Default Power window motor
I just replaced the motor. While screwing around with the regulator I ended up with a coiled spring ( 3-4 inches in diameter ) in my hand. Where does it go and how is it installed?
Old 05-20-2011, 12:36 PM
The only place that I am aware that has a coil spring like you describe is on the cross pieces near the center where they pivot. If you can't get a satisfactory reply , the only other thing I would suggest is to look at the other side and see just how the torsion spring is set on the regulator assy.
Old 06-15-2011, 10:48 PM
Superjim41's Avatar
That is defiantly were it goes just cleaned all the contacts and the window motor started working. The ford dealer said it needed a new motor>
spjoruss
09-15-2008 12:24 AM
roeboat109
05-28-2008 06:04 PM
harrand
10-20-2006 10:39 AM
scotrod65
11-29-2005 02:50 AM
degussa
06-07-2005 06:53 PM
Quick Reply: Power window motor
