05 f250 5.4l random multiple missfire
Old 01-20-2017, 12:08 PM
tbone187127's Avatar
Post 05 f250 5.4l random multiple missfire
hi my f250 has a random multiple misfire, and hard starting occasionally. i replaced the spark plugs and the fuel filter and help would be appreciated.
Old 01-20-2017, 01:19 PM
There could be several reasons for this problem.
There are scan tools that can help narrow down the area, time, and conditions that are producing the problem. It would be a good move to have the codes and conditions taking place read and disclosed when the misfires occur.
There is always the opportunity to go replacing parts with the shotgun approach, if you have unlimited funds, although not recommended.
Old 01-20-2017, 01:35 PM
yeah sorry should have mentioned that i have a scanner it gives me a p0300 code when going up hills or when i give it full throttle sometime it gives a cylinder 1 misfire along with the random misfire.
Old 01-20-2017, 03:11 PM
Does your scan tool provide mode 6 info? If so, that should tell you which cyls are misfiring and how much. At this point possibles could be cam problems with variable valve timing,coil problems, oil problems affecting cam timing, maybe even spark plug problems. Sometimes even a bad alternator can throw spikes into the system and the computer(PCM) doesn't like that.
Sometimes Ford computers don't always tell the truth regarding which cyls are misfiring.
86stang
01-20-2013 06:55 AM
cquam04
01-16-2012 06:13 PM
jeanette656
01-25-2009 09:21 AM
gdowle
09-11-2008 05:32 PM
dell
02-14-2006 07:46 PM
Quick Reply: 05 f250 5.4l random multiple missfire
