F-250 super duty
Old Sep 12, 2006 | 03:16 PM
1FAT250's Avatar
Default F-250 super duty
I just purchased a 2006 250 super duty diesel crew cap I was wondering could any body tell what is the biggest size tire I can put on stock rim with stock height also I have a superchip power programmer for sale for a 2001 f150 4.6
Old Sep 12, 2006 | 03:54 PM
Default RE: F-250 super duty
What rim size?
Old Sep 12, 2006 | 03:57 PM
1FAT250's Avatar
17" i believe 7' wide
Old Sep 12, 2006 | 04:12 PM
S/B a 17X7.5...
A 285/70/17 (33") will fit with no problems.. Anything bigger like a 315 would most likely rub.. The 265's are a 31.5-32 I believe depending on brands.. If you don't go to big there isn't any need to recalibrate for tire 'oversize' (gem module) as smaller dimensional differences are calculated for...
Old Sep 12, 2006 | 04:25 PM
1FAT250's Avatar
Ok thank you will look for some pro comps 285/75
Old Sep 12, 2006 | 06:02 PM
I don't know of any brand that makes a 285/"75"/17.. "YET" ..Could be wrong though
The 285/70/17 is a clean fit in that MY.. If you do go alot wider on rims, or much taller tires, you may have to do a slight lift, like 2" or leveling blocks for fit.. These trucks sit nose down in the front and would have to be leveled to go to a 9"wide rim or greater to avoid rubbing up front.. Running 'tall' sidewall tires also compromises the side wall for sway/stabilty as well..
Old Sep 13, 2006 | 08:22 AM
1FAT250's Avatar
that was a typo 75 I use to have 265/75 on my 150 how hard is it to do a 2" levelin kit would look it with pro comp 285/70
bigredtruck
May 29, 2008 11:58 PM
bigredtruck
May 19, 2008 12:49 AM
seandocf250sd
Aug 6, 2007 11:44 AM
1FAT250
Sep 12, 2006 03:16 PM
jasper
Nov 22, 2005 10:33 PM
