Battery light always on: 2004 F250 SD 5.4l
Just bought this truck with 233K miles and the alternator is a reman. Battery light is always on and would like some help to get it off. Here is what I have done:
1) Battery has 12.5V when engine is off and 14.4V when rnnign with A/C and lights on.
2) Took alternator to Advance and Auto Zone to have tested. Passed both places.
3) Took battery too and it tested good under load.
What else can I do?
Thanks,
Randel
What else can I do?
Thanks,
Randel
Welcome to the site..
Alt basics..
Key in the 'ON' position, voltage is applied through the 3 wire alt connector warning indicator circuit (LG/RD wire~light green/red tracer) to the voltage regulator and the regulator is then turned ON allowing current to flow from battery sense circuit (OG/LB wire~orange/light blue tracer) to the generators field coil. When the engine starts up, the generator begins to generate current through the output circuit (B+ or large alt terminal connection). Since your seeing a charge indication, then the regulator has been turned ON.
Once the generator begins generating current, a voltage signal is taken from the generators stator and fed back into the regulator through the stator circuit (S terminal/circuit or WH/BK wire~white black tracer). The voltage feedback signal of generally about half the battery voltage is used to turn 'OFF' the battery warning indicator/lamp. If the warning lamp isn't being turned off on a startup, check for the feedback voltage on the WH/Bk wire. Being it was bench tested and seemed to pass, does the voltage still stay within upper limits on the vehicle in higher RPM ranges with no added in loads?
Alt basics..
irinadel
07-30-2011 09:46 AM
nymotordude
12-07-2008 03:52 PM
