F350 7.3 Diesel
Old 09-15-2014, 03:10 PM
carolinacat's Avatar
Default F350 7.3 Diesel
I have a 2003 F350 7.3 Diesel and occasionally the power windows will not function at all. Typically this happens whenever I first start the truck. In addition to this problem, when the windows don't work neither does the radio. Nothing else seems to be effected. After the truck runs a few minutes the radio and windows will begin working again. I am wondering if it could be a short in the switch or something for it to affect the windows and radio. Any ideas from you Truck experts out there.
Old 09-15-2014, 09:27 PM
Thumbs up
Welcome to the site..
The power window and radio are on the 'Accessory Delay Relay' output circuit, and the delay relays control/coil power is through a closed Battery Saver Relay located within the instrument cluster. It's controlled by a micro processor within the instrument cluster. The Accessory Delay Relays ground function (to close the relay) is also controlled by the cluster processor. The Battery Saver Relay and Micro processor are not serviceable parts.
The Accessory Delay Relay is in the CJB (central junction box). It could be that the relay itself is failing, or, the cluster control components are the cause.
You can test for battery saver function/s and processor control at the delay relay connector (relay removed) and I can help with illustrated test points if you have a meter (?)
If it quits completely (window/s stuck down etc.) you can install a temp bridge across the connector to get the functions again.
Old 09-17-2014, 02:33 PM
Hey i would appreciate it if you could give us the information for the test points on the accessory relay. Thanks
Old 09-17-2014, 09:37 PM
Lightbulb
Sent some info to your reg. email.
Old 11-07-2015, 09:19 PM
Thomas kelly's Avatar
Hello, New the forum.
I'm having a problem with my 1999 f350 4x4 crew cab 7.3 diesel.
The windows (power) worked intermittent. Now they are only working when I unplug the switch and re-insert the plugs. They work for a short time and quit again. I checked for power on the Back of the plug when they are working. Power was good. But when not working the positive and the ground were both were showing voltage.
Than k s again Thomas kelly
Old 11-07-2015, 10:52 PM
When both sides show a positive voltage, usually it's because there is a missing ground connection.
Old 11-08-2015, 01:00 AM
Default 99 f350 Elec windows
When there is a ground missing, when and where are usual problem that have been reported or by your experience with such problems.
Thanks again . Thomas kelly
Old 11-08-2015, 06:29 AM
A schematic diagram is best to use for reference and at this time I don't have one handy. Without the diagram if you know which wires is the power supply the other should be the ground and would need to be physically traced to where it is secured to ground.
windystar
08-27-2019 01:44 PM
jpitura
12-15-2006 09:30 PM
john schrimpf
01-29-2006 03:10 PM
wannarace777
12-07-2005 03:44 PM
bburt2
09-11-2005 06:40 PM
Quick Reply: F350 7.3 Diesel
