Fuel trouble
Old 04-28-2013, 01:08 PM
mc1993's Avatar
Default Fuel trouble
I removed a leaking rear fuel tank on my '93 F-250 7.3L. I'll be running off the front tank alone, but engine is now running rough and smoking. I've plugged the supply and return lines going to/from the rear tank and have tried running out any air in the system. No luck. Is there a step or trick I've missed? I haven't has issues using the front tank before, so a bit perplexed.
Old 04-28-2013, 02:26 PM
Check the vent for the front tank. Make sure it is open.
Old 04-28-2013, 04:02 PM
mc1993's Avatar
I pulled the vent hose cap (per suggestion), but changed nothing. I've bypassed the tank selector valve since posting earlier. Thought I may have moved some sediment and plugged it, so I'm running direct from tank to pump, and return to tank. Its as if I'm getting too much fuel now, or starving it for air.
Can't imagine unplugging the rear sending unit has anything to do with anything....?
Old 04-28-2013, 06:14 PM
What is the color of the smoke you're getting?
Old 04-28-2013, 06:35 PM
mc1993's Avatar
It's white. Definitely fuel.
Old 04-29-2013, 09:05 PM
greasemark's Avatar
Have you run through whatever fuel was in the tank and tried some fresh?
alpoe
05-09-2015 02:13 AM
jodic
02-25-2013 07:09 AM
Bronco76Ranger00
11-08-2009 08:24 PM
nightmach
06-21-2009 06:29 PM
corecampaigner
04-11-2005 11:39 AM
Quick Reply: Fuel trouble
