Sensor checking 7.3 Ltr
Old 01-10-2017, 12:47 PM
eric hoffmeyer's Avatar
Default Sensor checking 7.3 Ltr
1999 7.3, 2WD, 6 Speed
There are several sensors on board (temperature, MAP, pressures and so on)
Is there a testing procedure for each of these?
I'd like to verify that they are all working.
Thank you.
Eric
Old 01-10-2017, 02:23 PM
Depends..
Some can be checked/probed and the data values checked with a DVOM. Generally, if out of spec. or fault the CEL will set. Hopefully A scan tool that can access the PID's (Parameter ID's or Parameter Information Display) to check the component parameters-data/values/voltages, live data/watch the overall ranges, in/outputs etc. is better and usually quicker diagnostics since some components rely on, or in part with communication..
clancy10
01-12-2012 04:14 PM
lawgger@telus.net
Canada, Over Seas & Elsewhere
06-12-2010 04:56 PM
SHOtime1
01-17-2008 09:20 AM
hightonedsob
07-13-2005 02:39 PM
hightonedsob
06-12-2005 09:29 AM
Quick Reply: Sensor checking 7.3 Ltr
