Flickering instument panel lights and ac noise
Old 07-30-2017, 04:48 PM
Ecrompt's Avatar
Default Flickering instument panel lights and ac noise
A day ago the instument lights ( including the clock, radio, and dashboard lights) in my ford 500 started randomly flickering. At the same time my air conditioner (which has dual air) started making a choppy/pulsing like noise. However, the air flow rate is steady. The noise tends to stop when I am in idle or driving at low speeds. In idle the rpm will occasionally flux from aroud 500 to 1000 also. The fan speed controller also doesn't work, but this problem existed prior to the others. I have no idea what is going on and was hoping for some insight.
My main concern is that I will be moving in a few days and am worried about something going wrong during my 1,400 mile drive from South Carolina to Iowa.
Old 07-30-2017, 08:07 PM
Good idea to have it checked and repaired before moving , you will have enough stress without worrying about what can go wrong next if you ignore the symptoms.
Old 10-01-2022, 06:06 AM
Shuntsman23's Avatar
Default Car won’t start
My mom has a 2005 Ford Five Hundred 40k miles And the back up lights were on when in park or driving. And the dash lights did not come on. They replaced the battery and alternator. And a week later the car won’t start now. It has been connected to the computer 3 times and shows no codes.
Kristófer Óskarsson
04-22-2018 06:08 PM
Kat Cavanaugh
08-17-2017 04:25 PM
Kat Cavanaugh
08-17-2017 04:25 PM
golem
04-19-2013 09:20 PM
MikeMurphyinKY
01-09-2007 03:00 AM
Quick Reply: Flickering instument panel lights and ac noise
