Install new chrome oil tube
If it is safe to assume you are talking about the oil dipstick tube, You might try a LITTLE pipe joint compound around the end and make sure the tube is supported so it can't work loose. Also if it has a stop ridge , which most do, roll an "O" ring on it and then when inserted it should seal the joint.
If it is the oil fill tube you can try the same methods.
svtsnakebyte
07-29-2015 09:00 PM
NOLAgsxr600
09-09-2007 01:40 AM
ckandes1
05-20-2007 12:56 PM
