Install new chrome oil tube
Old 03-15-2014, 01:10 PM
Soapster's Avatar
Default Install new chrome oil tube
What can I use to stop the oil tube from leaking before I beat the tune into the block.
Thanks for any input.
Soap
Old 03-15-2014, 01:21 PM
If it is safe to assume you are talking about the oil dipstick tube, You might try a LITTLE pipe joint compound around the end and make sure the tube is supported so it can't work loose. Also if it has a stop ridge , which most do, roll an "O" ring on it and then when inserted it should seal the joint.
If it is the oil fill tube you can try the same methods.
Old 03-15-2014, 07:57 PM
Soapster's Avatar
Yes it is the dipstick tube. It has a stop ridge, however the tube goes in at a 45 degree angle which will not let the ridge set flush. 66 Ford 390. I need something that can take the heat.
svtsnakebyte
07-29-2015 09:00 PM
markcross
12-30-2008 02:10 AM
NOLAgsxr600
09-09-2007 01:40 AM
ckandes1
05-20-2007 12:56 PM
elbert
11-19-2005 01:33 AM
Quick Reply: Install new chrome oil tube
