2004 Freestar rear lift gate handle
Old May 21, 2012 | 07:04 AM
  #311
minnesotamike's Avatar
jcbuterbaugh & TerriB,
Just sent them to you.
Old May 21, 2012 | 08:06 AM
  #312
TerriB's Avatar
Default Thanks so much!
Greatly appreciate it!
Old May 22, 2012 | 06:52 AM
  #313
You're welcome.
Old May 22, 2012 | 01:46 PM
  #314
manismani's Avatar
Thank you "racer44' I will try this.
  #315
manismani's Avatar
Thank you I will try this.
Originally Posted by minnesotamike
manismani,
Welcome to the board. I'm not sure if this will help, but you can try. There is a small 1" x 1" access hole near the inside handle. Pop the cover off and try to locate a white plastic lever in there. Try to move the lever to the left with a screwdriver. You could also look to see if there is a cable attached to the lever. If you don't see the cable, then it probably broke or disconnected. In that case, I'm not sure what the best solution is.
Old May 24, 2012 | 02:56 AM
  #316
outinthestix's Avatar
My 2004 Ford freestar rear lock hatch latch assembly is broken and needs to be replaced. Does anyone have a schematic of the assembly or removal instruction?
thank you very much, Eric
Old May 24, 2012 | 07:34 AM
  #317
They're on their way.
Old May 24, 2012 | 04:02 PM
  #318
wow...thank you so much minnesotamike
cant thank you enough!!
Eric
Old May 25, 2012 | 06:54 AM
  #319
You're welcome, outinthestix.
Old May 25, 2012 | 12:06 PM
  #320
Thanks MM for you continued support of the thread and member help!
FF Members,,,
If any help requests are sent, PLEASE use the Member Search/PM contact function within the site to send email contacts or personal information 'member to member' for your protection. Anyone putting email (or phone) contact info within a thread here or classifieds should mask the address for at least minimal protection..
Sample-
newmember123atcomcastdotnet
