2004 Freestar rear lift gate handle
I have seen some with problems of the handle breaking off...and a few that seem to have a problem of door not unlocking. I seem to be having the latter problem. I have a 2004 freestar....I can no longer get the hatch open, doesn't sound like it is unlocking. Tried removing the little 2" square on the panel but don't see anything but foam. Any suggestions how to fix problem so I can open hatch again? Thanks!
You need to remove the interior trim to get the door open. Open your side doors and get a fan set up to blow on you in the van. It gets warm quick even in the shade. Ford has new actuators for around $50. Start at the top trim panel where it meets the bottom. Pull it away froom the ahtch firm yet gently. You will see the clips pull at the trim as you pull them from the frame. Pull to hard and you will pull the clip out of the trim.Work your waqy around the top trim and then remove. The interior handle is held by (2) 8mm bolts, and two philip screws at the bottom corners. Then pull at the clips around the lower trim piece. Work the trim piece off the bottom of the hatch. It is difficult yet can be done with hatch closed. *I did it* Put a screw driver in the metal piece of the actuator and push it to the left. You should hear the door release as if you pulled on the outside handle. * Power lock should be open.* After you open the hatch there are 3 philip screws on the bottom edge to renove the actuator and replace with the new. Remove the 2 electrical clips from the old actuator and reattach to the new one. Do the reverse to put it all back together.
We have taken the little square off and moved the little white thing and that moves but the door still will not open if you could please send me anything on how to open the hatch and fix this problem you would make my day Thank you.
Is the cable attached to the white thing? Did you try getting a hold of the cable and pulling it? I'll send you the schematics, but I'm not sure they will help since I'm not sure you can take the inside panels off without the door being open. Maybe somebody else has an idea.
Mike
Mike
I just read there is a recall for the 2005 liftgate module, whatever that is. I used "ask.com" and ask if there are any recalls on the brake system and found this recall on the liftgate. I need help with the brakes on my 05 freestar as ive replaced the master cylinder, pads, and a valve! Please help!
