freestar rear window defoger
Old 07-16-2013, 08:22 AM
dimasp28's Avatar
Default freestar rear window defoger
Good day everyone !!!! Just a plain question: How I can reattach the contact for the rear window defogger,(looks it was originally solder to the glass), is three any kit or glue to do this?
Thanks
Dimasp28
Old 07-24-2013, 01:57 PM
StuartBinny's Avatar
When the rear defroster does not work at all, small breaks in the horizontal grid can be eliminated as the problem. In this case, all of the horizontal defroster grid lines would need to be broken and it is very unlikely that this would happen without it being immediately obvious. Begin trouble shooting a total grid failure by carefully inspecting the thick vertical side bars of the defroster. A break or scratch in one of these bars could cause the defroster to fail completely.
Use the Frost Fighter Defroster Grid Kit to repair any small breaks or scratches in these critical side bars.
The more likely cause of a total defroster grid failure is a separated main power clip/tab. These critical tabs connect the defroster grid with the vehicle’s high amperage defroster circuit and are located on each of the defroster grid’s vertical side bars. These all important tabs can be knocked off of the defroster causing total defroster failure. Look for dangling wires near the sides of the defroster as a sure indication of this problem.
2004freestarmatt
10-31-2022 08:55 AM
ispyincornermyi
06-17-2019 06:27 PM
Chem
07-29-2012 12:41 PM
FreestarMontreal
05-10-2010 07:38 AM
Smakboy
05-07-2008 12:03 PM
Quick Reply: freestar rear window defoger
