Power Sliding Door Cable
Old 10-18-2016, 12:58 AM
Sland165's Avatar
Default Power Sliding Door Cable
Hello All!
Just picked up a 04 Freestar SEL to lug some kiddos around town for the practices etc. Previous owner took decent care of it with a few minor blems. One that I want to get fixed rather quickly is the driver's side power sliding door. The foreward cable looks to just have snapped and in the process creating slack for the rear to come undone as well. I am looking to locate where the motor is housed so I can take a peek and see what I wanna do as far as fixing the issue. I am guessing it is easier to just purchase a whole 'nother motor assembly versus trying to fix cables. Door opens and closes manually just fine, but want to get the lazy feature back on it TYIA
Old 10-18-2016, 06:44 AM
primem's Avatar
most models house the motor behind the quarter panel trim.
Old 04-25-2019, 10:33 PM
sharbelhaj's Avatar
Default freestar sliding door motor.
Originally Posted by Sland165
Hello All!
Hi,
it is located inside the driver side back panel, you will need to unscrew the two screws on the bottom left and the one on the top if any!
then you need to carefully pull the side panel out and you will see it right behind it.
let me know if i can help any farther.
Good luck.
Freestar_2004_Owner
06-21-2018 05:59 PM
localboy
09-24-2015 03:40 PM
Kyle700
09-04-2014 01:03 PM
guthrie35
01-07-2010 09:17 PM
Smakboy
05-07-2008 12:03 PM
Quick Reply: Power Sliding Door Cable
