check engine light 98 ranger
Old 02-16-2014, 11:56 AM
LILRANGER's Avatar
Thanks for the guide. I did clean the MAF properly with the correct cleaner and followed the directions on the can and also watched multiple how to do video's.
Now I did find something that is making some sense. With the engine running I couldn't find or hear a vacuum leak however when driving as I would come to a stop and take off from a stop I would hear what would sound like a vacuum leak. When stopped no sound, just when applying the brake as stopping I would hear it and when taking off It sounded like a reverse sound of it.
When looking at my passenger front brake I followed the vacuum hose from the caliper up to a rubber connector and notice a screw in one side (the passengers side) of the connector and the other side with no screw but looked as a screw was once in it.
I put a screw in it and its been a week without a check engine light and no sound.
Any thoughts?
  #12
Old 08-01-2014, 09:32 PM
LILRANGER's Avatar
It looks like I fixed it. I put a new fuel filter in and the check engine light hasn't been on for months now.
  #13
Old 08-02-2014, 04:45 AM
Good !
Have you checked if your front hubs engage like they are supposed to before the cold weather hits and then you find there is a problem?
  #14
Old 09-10-2014, 05:52 PM
LILRANGER's Avatar
I have electric engaged 4WD. My 4WD does work in high and low traveling straight down a road however when I turn the steering wheel it feels as if my parking brake is on . Got any ideas what that could be?
  #15
Old 09-12-2014, 11:02 AM
Are you sure the 4WD is actually disengaging?
  #16
Old 09-12-2014, 08:06 PM
LILRANGER's Avatar
What I'm saying is when I am using my 4WD and I'm driving to work in the snow everything is good however, when I slow to turn into a parking lot it feels like my parking brake is on. When I straighten back out its good again.
  #17
Old 09-13-2014, 01:57 PM
grindman's Avatar
it sounds to me that when you're turning into the parking stall the front cv joints are getting into a bind
  #18
Old 11-19-2014, 04:18 AM
John Renold's Avatar
Hey guys! In my Ford Ranger 98, How do i get the check engine light to go off? I have changed the pvc, gas cap, and 3 oxygen sensors. But the light is still on. Please help me friends.
  #19
Old 11-22-2014, 10:55 AM
LILRANGER's Avatar
Default check light
this sounds weird but, change ur fuel filter. it worked for me. other than that u have a vacuum leak. check my passed posts. good luck
Newman271
03-21-2021 12:54 AM
sky81
01-27-2013 11:27 AM
allensimpson
01-10-2008 09:40 PM
dwight
10-16-2007 10:24 AM
kurt k
04-01-2007 08:35 PM
Quick Reply: check engine light 98 ranger
