Ford Sport Trac SUV seating and versatility meets the compact pickup truck in this crossover.
Ford Sport Trac Stops running when hot
Old 10-30-2011, 03:53 PM
Bones2011's Avatar
Default Ford Sport Trac Stops running when hot
Hello,
I have a 2005 Ford Explorer Sport Trac 4X4. The engine stops running after a few minutes, and then won't start again until it cools off.
Also Engine light came on when the problem started.
Any ideas?
Old 10-30-2011, 05:59 PM
Whatever it is appears to be temperature related. It would help if you were able to get the code(s) in the PCM (powertrain control module).
Do you hear the fuel pump run for the 1-2 seconds when you try to restart it?
Old 10-31-2011, 06:39 PM
Bones2011's Avatar
I definitely hear the pump when I try to start it. Not sure how to get the PCM codes that you mentioned.
I took it to the dealer for diag\repair. I will let everyone know what it turns out to be.
Old 11-03-2011, 10:20 AM
steave's Avatar
what did he say?
explorerman
05-10-2016 11:56 AM
Towguy76
05-22-2013 12:01 PM
Freedomdriver
07-13-2011 05:25 AM
Ihavefordparts
01-23-2011 11:13 PM
pam_210
01-21-2008 12:45 AM
Quick Reply: Ford Sport Trac Stops running when hot
