Ford Sport Trac SUV seating and versatility meets the compact pickup truck in this crossover.
Starter solenoid
Old 08-16-2015, 08:21 PM
Damandaplaya's Avatar
Default Starter solenoid
I have a 2001 sportTrac. The starter solenoid IS NOT on the fender as Advance tells me. There is a solenoid on the starter up underneath the car. Are there two solenoids? I'm not a mechanic but I have changed a starter solenoid on a previous vehicle; it was not this complicated
Old 08-16-2015, 08:57 PM
primem's Avatar
looking at the wiring diagram I have; there is a starter relay in the left rear of the engine compartment and the starter solenoid is on the starter motor.
Old 08-16-2015, 09:25 PM
Thank so much for answering. It's the one in the left rear of engine I can not locate. Does it look like a solenoid or is it a little switch?
Old 08-17-2015, 12:43 AM
Use Common Sense's Avatar
A starter relay will look like this animal. It's about 2" in diameter and 2" tall.
Old 08-17-2015, 07:16 AM
primem's Avatar
start either at the battery + or starter motor. follow the large battery+ cable as it routes from the battery to the relay to the starter.
Old 08-17-2015, 04:01 PM
After finally going to a Ford dealer asking for parts, I figured it out. It appears the only starter "solenoid" on this version of Sport Trac is on the starter, which you have to put car on jacks to get to, as it's right next to the oil pan. The "relay" switch (is what I'm calling it) is a fuse type thing in the power junction box. However every auto parts store I went to tried to sell me the fender mounted solenoid, which does not exist for this version of Sport Trac.
Old 08-22-2015, 07:45 PM
primem's Avatar
now you know why the dealer wants your vin every time you enquire for parts. vehicles today are very build specific.
Old 08-24-2015, 03:54 AM
Yep...Build specific along with the "Built before, Built after, Built during, Built in between, Built while" and so on.
trschroeder
03-01-2012 05:34 PM
todd-shelton
12-26-2010 01:12 PM
buymoreguns
01-29-2009 10:36 AM
jdm
02-26-2006 08:38 PM
redtide265
06-29-2005 04:48 PM
Quick Reply: Starter solenoid
