Ford Tempo/Probe These small cars offered a sporty feel and affordable price.
90 probe gas gauge not working
Old 12-21-2014, 08:42 PM
austio117's Avatar
Default 90 probe gas gauge not working
i just bought a 1990 ford probe and the gas gauge does not work. Was wondering what could possibly be wrong. Please help.
Old 12-22-2014, 05:11 PM
I know you said the gas gauge doesn't work, but what is it doing , stuck in one place , stay on empty/full ? Each one of those symptoms could have a different cause.
Could you be a little more specific?
Old 12-22-2014, 09:25 PM
austio117's Avatar
The gas gauge is stuck on empty.
Old 12-23-2014, 05:04 PM
These are some of the causes for the gauge to stay on empty.
The wire from the fuel tank sending unit to the gauge is separated / open some where.
The float has come off the float arm on the sending unit in the tank.
Gauge faulty (not very likely).
There are usually two wires going to the sending unit in the tank, ground, signal return to the gauge.
If you ground the wire at the sending unit that goes to the gauge the gauge should read full. That will prove out the gauge and the wiring. If that is OK the sending unit will need to be removed to confirm the float is still attached , If so, sending unit is defective.
If the wire to the gauge when grounded causes no reaction , you may need to get into dash to ground the wire at the gauge to confirm gauge is good or not.
soopacee
04-17-2015 06:13 PM
forthvacav
12-16-2008 08:14 AM
tfunk002
12-26-2006 09:24 PM
blake
08-08-2006 12:43 PM
blake
08-05-2006 11:35 PM
Quick Reply: 90 probe gas gauge not working
