94 tbird lx
Old 12-09-2007, 07:31 PM
eddyroz6's Avatar
Default 94 tbird lx
just replaced calipers rear on my tbird and i found that they are leaking brake fluid from the brake line fitting that attaches to the calipers i dissasembled ,checked and reinstalled and still leakin any advice out there ..........thanking u in advance for ur input.............
Old 12-09-2007, 11:25 PM
Default RE: 94 tbird lx
If they are leaking from where the bolt goes through the banjo fitting then replace the copper washers, there are 2 washers 1 on each side of the banjo fitting end. If it's leaking from where the rubber hose attaches to the banjo fitting they you will need to replace the hose.
Old 12-11-2007, 11:16 PM
goinstrong's Avatar
I agree - copper washers 4 sure unless the threads are stripped off. Maybe check the bleeder screws are tight too. Copper washers could be filed flat with a file - but you can not humanly deck both sides evenly and you may need certain thickness of the washers to seal if the bolt threads stop at a set point (requiring thicker or doubled washers).
885.0tbird
11-16-2013 03:10 AM
885.0tbird
01-28-2011 11:45 AM
kraussy783
03-25-2007 02:37 AM
Midnight Special Rac
07-03-2005 03:19 AM
hepcatws6
08-21-2004 03:02 AM
Quick Reply: 94 tbird lx
