Should I cut this out? Dash interior question.
Old 07-09-2013, 01:43 PM
Benkiller's Avatar
Default Should I cut this out? Dash interior question.
My goal for the day was to convert my single din radio to a double din radio. What I did first was obviously remove the dash, including ac control panel. The only way in a 1995 ford thunderbird to convert it to a double din it to us the top 2 dins. Doing this you have to move the ac control panel all the way down to the bottom storage slot. With a little bit of shaving an wire stretching it slides right in. So I did all that, then I cut all the plastics beams that were stopping it from sliding in. After allll that I went to put the radio in, and come to find out there was a metal beam stopping it from sliding it all the way in. The beam is about 1" wide, and it pretty thin, but very solid. It doesn't look like it is holding anything up. My question is would it hurt to remove that beam? It is right behind where a standard radio would sit. Any suggestions?
http://i41.tinypic.com/2ed5csp.jpg
http://i41.tinypic.com/5vbxqa.jpg
http://i44.tinypic.com/2ymvmte.jpg
Sorry about the horrible quality of the pics. But here's the beam.
If you need more pics just ask and I will go out and take them.
Old 09-26-2013, 06:49 AM
Tweety Bird's Avatar
Arrow
I just bought a 95 40th Ann. T-Bird, and will pick it up tonight. I too, was considering a different stereo for it. BUT, because it is a 40th Anniv., I decided against it. (The car has all of the badging, and decals).
I did find some nice single din units, that weren't quite as bad looking as the standard aftermarket unit.
Good luck !!
Sgtguerra
09-12-2013 11:45 AM
ac917x
01-15-2012 06:12 PM
Bbarrier1
06-17-2011 06:10 PM
artcat99zl
05-04-2011 11:54 AM
shagwagon
03-05-2008 09:33 PM
Quick Reply: Should I cut this out? Dash interior question.
