83 T-bird Ac issues
Old Aug 27, 2010 | 03:09 PM
erc004's Avatar
Default 83 T-bird Ac issues
I have a 83 t-bird with AC problems. When the engine is cold the ac blows cold air. After the engine gets hot it blows hot air. The freon is full and clutch is working. Any ideas?
Old Aug 28, 2010 | 08:57 AM
stuart40ca's Avatar
It could be a blend door not closing or opening.
Check for vacuum leaks.
Is the condensor clean?
You mention full of freon, have you had the pressure taken?
Old Sep 1, 2010 | 06:47 PM
erc004's Avatar
Default Blend door
I figured out it is a problem with the blend door opening and shutting on its own. Anyone know how I can fix that issue. A diagram or something?
Old Sep 2, 2010 | 07:16 AM
stuarta's Avatar
If a door is operating by itself that means there is a vacuum leak.
Check the entire vacuum system, the leak could be anywhere.
dwarber
May 4, 2025 11:31 AM
tdkruse
Apr 7, 2016 01:22 PM
maiden_fan
Jul 25, 2014 06:02 PM
80t-bird
Sep 24, 2012 01:35 AM
dave00beer
Dec 1, 2006 03:19 PM
