1975 ford gas mileage
Old 06-09-2010, 07:47 PM
Pat99's Avatar
Default 1975 ford gas mileage
alrite i have a 1975 ford f-150 with the 390 in it and it didnt get good gas mileage to start out with but a couple weeks ago it started getting way worse. i looked around and i couldnt see any gas leaking. i was told maybe a carburetor kit would be the solution. any thoughts?
thanks
Old 06-10-2010, 06:39 AM
Before digging into the carburator, when was the normal drivability/fuel mileage affecting items changed last? These would be plugs, cap, rotor, plug wires, air filter and fuel filter. If these are all good, then I would start with checking to ensure that the choke opens fully when the engine is warmed up. If it doesn't open fully, you'll be running rich all the time. Do you have a 2 Bbl or a 4 Bbl carb?
Old 06-10-2010, 11:20 AM
hotrodstude's Avatar
Default 390
startwith a good tuneup and then see how your gas miliage is doing then get back with us
Old 06-10-2010, 12:46 PM
Pat99's Avatar
its a 4 bbl
Old 06-11-2010, 05:49 PM
Pat99's Avatar
does anyone know of a website where i could find a diagram of the carb and the engine compartment
rhmc24
12-26-2010 10:56 AM
hotrod
08-01-2010 01:31 PM
Pat99
06-15-2010 04:56 PM
jiggles
08-28-2009 09:32 PM
studebaker
01-21-2008 08:08 AM
Quick Reply: 1975 ford gas mileage
