Aspire/Festiva/Fiesta Possibly one of the original "sub compacts" this car offered amazinf fuel economy.
stepped on the "new " clutch.
Old Aug 31, 2019 | 12:21 AM
fastonraceday's Avatar
Default stepped on the "new " clutch.
the pedal went right to the floor real easy and the lever moved out on the tranny. is something missing.
Old Aug 31, 2019 | 01:21 PM
It certainly is !!
Nice to know what you might be driving,
year , model, exactly what you did. The more info you can supply the better.
If the vehicle has a mechanical clutch linkage and not hydraulic,, it sounds like the clutch fork was not fully mounted on the ball stud. If that is the case you probably could reinstall everything making sure you get the fork contacts correctly indexed with the release brg and properly mounted on the ball stud.
Not knowing exactly what you did , that is about the closest I could come as to why the fork slipped out,,,,,,,,,,,,,,,,if that is what actually happened.
Old Aug 31, 2019 | 11:51 PM
Default Stepped on a "new"clutch.
The car is a 1995 ford aspire and the previous owner supposedly put in a new clutch by taking out the en gine instead instead of the transmission.
Old Sep 7, 2019 | 06:42 PM
i got everything else working except the headlights, blower fan, and interior light. the car runs fine. going to work on the clutch next. is the tranny difficult to take out? someone said i had to support the spider gears or they will drop. i had a haynes manual but put it aside and now i cannot find it.
Old Sep 7, 2019 | 10:12 PM
If you need to remove the trans, I can send you the shop procedure/illustrations for the job..
Same with the electrical drop outs,, if your up for some test, let me know.
Old Sep 7, 2019 | 10:31 PM
i am up for it. i got the headlights working, the drivers' side is a bit dim probably a bad ground the interior light needs a bulb, the fan circuit was bypassed with a hot wire to the motor and wrapped with electrical tape. i got the whole center consol apart it was full of garbage and cigarette butts. i am going to take the seats out and the carpet and clean everything real good.
hfd
Jan 12, 2014 08:33 AM
tdconerly
Jan 3, 2009 07:16 AM
bafflingsteveo
Jun 23, 2008 10:54 PM
adb135
Sep 18, 2006 11:29 PM
Range96
Aug 5, 2005 06:32 PM
