Ford Bronco One of the original SUVs, offered in both a full size Bronco, or the more compact Bronco II.
1989 Bronco 2 - Electrical Issues
Old Feb 18, 2022 | 06:11 PM
  #11
Landmann's Avatar
Default Fuel pressure
42 PSI is fuel rail pressure. I will check to see if ECA is pulsing ground when motor is turning over at ECA. I am currently running on external fuel pump. Replacing the fuel tank, pump and associative parts.
How would you test ground at ECA?
Old Feb 18, 2022 | 07:26 PM
  #12
We are going to start this from the beginning.
When you first turn the key on does the fuel pump run at all, and if so how long? Yes/No
When you are cranking the engine over does the fuel pump run? Yes/ No
POWER GROUND CHECK
Key On,Engine Off
Connect DVOM (-)to Battery Negative
Connect DVOM (+) to Pin 40 Power Ground
Voltage should be less than 0.5 volts
Connect DVOM (+) to Pin 60 Power Ground
Voltage should be less than 0.5 Volts
If fails, Service PWR GRD.
CASE GROUND CHECK
Key On Engine Off
Connect DVOM (-) to Pin 60
Connect DVOM (+) to Pin 20 PWR GND
If more than 0.3 v ,Service PWR GRD
To do these checks you may need to use a T pin to make the connection at the ECA by carefully sticking the pin into the wire just enough to make contact. You will also notice On Fords , most of the time , the grounds are Black wires.
chad3240
Jul 14, 2013 06:44 PM
Stapuph
Sep 23, 2010 09:13 AM
grumpydave
Jan 18, 2008 03:15 PM
reinholdt
Jan 15, 2007 04:17 PM
pmsemye
Mar 14, 2006 01:17 PM
