Ford Bronco One of the original SUVs, offered in both a full size Bronco, or the more compact Bronco II.
1995 Ford Bronco XLT 5.0 L power, but no start. Need advice.
Old Mar 31, 2019 | 10:06 AM
pkramer66's Avatar
Default 1995 Ford Bronco XLT 5.0 L power, but no start. Need advice.
Hi Guys!!
One day my step-sons truck would not start, would not start with a jump.
The coil replaced, ignition control module changed, checked battery, all wire clips, checked timing. Truck is getting power to the coil but no spark, no gas smell, so I do not believe it is flooding either.
Fuel pump is working.
Truck cranks over but will not start, engine light is on but can't get codes read because I cannot get it to start to take anywhere.
Any advice is appreciated!!!
Old Mar 31, 2019 | 02:56 PM
I guess this is one of those times where we start from scratch.
As far as spark is concerned, IF, it has a distributor (transition year) we need to know if the dist shaft is turning when the engine is being cranked. On some Fords the check engine will go out when cranking.
Does it go out?
Also, remove the dist cap and see if the rotor is turning when the engine is being cranked.
If all that passes , there is a pick-up coil in the dist that provides a signal that the engine is turning over. That signal goes to the Ign module.
You can hear the fuel pump run for the usual 2 seconds when you first turn the key on? Yes- No ?
What kind of test equip do you have to work with?
Old Apr 2, 2019 | 07:00 PM
pkramer66's Avatar
Thank you for your rely.
Yes to all of your questions-the engine light does flash when cranking.
The only test equipment I have access is a test light and a voltage-ohm meter.
Old Apr 3, 2019 | 01:28 AM
If you connect the test light to the + terminal of the battery and the probe end to the side of the coil that comes from the module, when you crank the engine over the test light should blink as a ground is applied to the coil. What does it do ?
Old Apr 3, 2019 | 06:18 PM
pkramer66's Avatar
Hi, we did the test as you suggested, test light to + side of battery, probed the test light to coil plug right side which is a red wire light was on, turn the key to start the truck, the light went off and stayed off. When key was turned back off, the light came back on-solid.
Probed the left side wire of the coil (negative) light came on, turned the key to start the truck, the light became dim and slightly pulsated.
Old Apr 3, 2019 | 06:19 PM
pkramer66's Avatar
on the last wire tested (negative) when key was turned off, the light became bright.
Old Apr 3, 2019 | 06:21 PM
pkramer66's Avatar
Also, did a test and code 111 came up, which means "system normal".
Betty Lapierre
Sep 5, 2024 06:28 AM
ROTODISC
Feb 2, 2017 03:20 PM
wayneswirld2
Jan 27, 2017 06:41 PM
Bena8837
Aug 3, 2015 02:21 PM
elitethrilla
Sep 2, 2012 10:28 AM
