Ford Bronco One of the original SUVs, offered in both a full size Bronco, or the more compact Bronco II.
tricky idle
Old Jul 26, 2009 | 08:19 PM
lone_ranger_03's Avatar
Default tricky idle
i have a 87 ford bronco II and the idle fluctuates considerably to the point it will die. plus when trying to accellerate off idle it hesitates like it wants to die depending on how much throttle i give. now from the info iv'e gathered here it could be a vacuum leak or a intake manifold leak. any suggestions on ways to verify which it could be or where to look for the leak?
Old Jul 27, 2009 | 08:48 AM
Bullitt94's Avatar
The way to check for an intake leak is to take carb cleaner and spray it around the seals of the intake while the vehicle is idling. If the engine revs while doing this, then there is a leak.
Old Jul 27, 2009 | 10:45 PM
Default duh
hah-ah that makes perfect sense and yet so simple, thanks i give it a try.
Old Jul 28, 2009 | 04:35 PM
Bullitt94's Avatar
Let us know how it turns out.
Olpapa
May 18, 2008 03:22 PM
rippedrob420
May 29, 2007 10:06 PM
