Ford Contour While only built on a short time span, the Contour was very popular with people of all driving styles, from the base model making for a great family car, to the SVT making a great track toy.
brakes bog it out and hissing sound.
Old 12-18-2015, 09:21 AM
hearseback's Avatar
Default brakes bog it out and hissing sound.
What the titles says. Assuming vaccuum problem. Maybe hose to booster? It just started after I replaced the hose from the the air filter to the head gasket. So im assuming I knocked something loose.
Old 12-18-2015, 12:26 PM
If you didn't have the problem before replacing the hose it is a good bet you are correct . Just double check everything you were near and you should be able to spot the problem. (You did use the correct size hose, right?)
pesky
06-17-2012 07:05 PM
jalpern
04-10-2011 09:44 PM
keiser1042
01-04-2011 12:05 PM
epgarvey
12-26-2007 09:43 AM
scout7pg
09-02-2007 01:25 PM
Quick Reply: brakes bog it out and hissing sound.
