Ford Contour While only built on a short time span, the Contour was very popular with people of all driving styles, from the base model making for a great family car, to the SVT making a great track toy.
Fast Idle - New IAC & TPS
Old Jan 24, 2011 | 08:53 AM
mmichaelk's Avatar
Default Fast Idle - New IAC & TPS
I have a 99 Contour with the 2.5 auto. It idles at about 1100 rpm and when in drive, creeps up to 1700 with no gas pedal applied. In the morning when it's cold, the first time you start it, the rpms jump up to 2000 and then drop to nothing and it stalls out. I'm picking up a 1506 code (Idle Overspeed).
I've replaced the TPS and IAC. Any thoughts?
Old Jan 24, 2011 | 05:39 PM
A good place to start is see if you have any vacuum leaks. the evap canister valve may be stuck open, Inspect the entire intake system from mass air flow sensor(MAF) to the intake manifold for damage or leaks. It sounds like extra air is getting into the system and the computer is trying to correct a lean condition. Where all incoming air is measured by the MAF and fuel is adjusted accordingly additional unmeasured air may be causing the ECM to attempt to correct a lean mixture.
Old Jan 25, 2011 | 08:18 AM
mmichaelk's Avatar
Default Where Is The Valve Located?
Thanks for your advice. I was thinking vacuum leak as well. I've done a trace back (as best I can) from the MAF but didn't see, hear or feel any leaks. Everything seemed attached and no split lines. However, I didn't check the canister. According to Chilton's, it's located under the spare tire well at the back of the car. Where is the valve for it?
Thanks.
Old Jan 25, 2011 | 01:40 PM
The only suggestion I can offer at this time is , trace the line coming from the canister to the intake manifold and the valve is located in that line and is electrically controlled. It's the only valve in the line and once you find it you may be able to close it off and see if it effects any change. I believe in your model it's in the engine compartment , but not positive.
searchlight4759
Jun 16, 2015 08:08 AM
kevhed
Jan 16, 2007 01:06 PM
mr2 in nl
Jul 29, 2006 11:03 PM
fred_penner
Oct 28, 2005 02:41 PM
