Ford Contour While only built on a short time span, the Contour was very popular with people of all driving styles, from the base model making for a great family car, to the SVT making a great track toy.
oil on sparkplugs
Old Oct 11, 2007 | 10:10 PM
plyguard72's Avatar
Default oil on sparkplugs
Hi, I have a 1998 Ford contour 2.0 DOHC 123000 miles which runs like a charm. I decided to replace the sparkplugs( it was due). The sparkplugs were coated with some oil when pulled out. The car starts fine, does not run rough, and does not burn oil. I have done some research online and some suggestions were to replace the cylinder gasket and/or sparkplug tube gasket. It sounds like an easy fix but i just wanted to know if there was something else i should be addressing. thanks for any input.
Old Sep 13, 2008 | 01:54 AM
grampztoyz351's Avatar
Default RE: oil on sparkplugs
sounds like the same problem I had with a 2000 focus and currently having with my '97 contour.I replaced the valve cover gasket on theFocus problem solved,as soon as I can afford to do it I'm going to change the Contour. Money's tight laidoff
Daarrve
May 12, 2011 08:50 AM
REORACING
Aug 17, 2009 05:55 AM
PTT
Jul 4, 2007 08:33 PM
Sparkplugs.com
Dec 1, 2006 03:03 PM
Patrick
Dec 1, 2006 01:06 PM
