Ford Contour While only built on a short time span, the Contour was very popular with people of all driving styles, from the base model making for a great family car, to the SVT making a great track toy.
Replaced engine - won't start
Old Sep 12, 2009 | 08:05 AM
billm's Avatar
Default Replaced engine - won't start
1996 Ford Contour with 2.0 engine
Original engine overheated, purchased salvaged engine and installed over Labor Day
Installed several new parts like timing belt, water pump, radiator, etc.
Put old flywheel on replacement engine.
Repaired insulation on several wires coming across top of radiator
Engine will turn over, but not start
Had to replace crankshaft sensor plug with best available fit from junkyard
Power is present at coil pack, fuel rail, and crankshaft sensor
Have fuel pressure, but no injection, also no spark at plugs
Swapped old crankshaft sensor, no help
No codes indicated on analyzer
dinkydow3
Dec 16, 2012 09:45 AM
cubuffs
Mar 23, 2008 12:22 PM
nflz32
May 10, 2007 02:35 AM
funkdoobiest
Feb 11, 2006 05:16 PM
patterus2002
Jul 26, 2005 12:57 AM
