1983 LTD crown vic idle too high
Old Jul 1, 2016 | 12:16 AM
Radu Georgescu's Avatar
Default 1983 LTD crown vic idle too high
hi
bought today this 83 crown victoria and the idling appears to be high.
is there any adjustment to it? such as an idle control valve? I do not hear any vacuum leaks.
is there any DIY troubleshooting guide?
I have experience with fuel injection but not with this model
Thanks!
Old Jul 1, 2016 | 12:31 AM
I also have some problems with the fuel level. What is the spec (ohms at Low / Full) for the fuel level sending unit and where can I find it?
Old Jul 1, 2016 | 06:15 AM
Use Common Sense's Avatar
Does it have the 5.0L w/CFI or 5.8L w/CARB engine?
Old Jul 1, 2016 | 02:27 PM
here is a picture.
which one would this engine be?
Old Jul 1, 2016 | 04:37 PM
Hope you guys don't mind , but I think I see a throttle control piece and It does appear to be with a carburetor. I could be wrong !
Old Jul 5, 2016 | 03:51 AM
A picture without the air cleaner on the intake would be more useful to easily identify what you have.
Hanky is right, the throttle control piece appears to be for a carb so the idle should be adjustable.
Here's a picture of a CFI unit...
Old Jul 26, 2016 | 07:31 PM
My engine is 5.0 fuel injected. And the cause for the too high idle was the throttle wasn't closing properly. Either dirty or the spring got too weak. Push it back with the hand and it idles correctly. So not a big problem!
87Mojo
Jun 4, 2019 05:41 PM
One to Remember
May 20, 2013 11:26 PM
dinkydow3
Dec 16, 2012 09:45 AM
87crownvic
Mar 16, 2010 02:00 PM
cardinal33
Jan 15, 2008 08:34 PM
