2001 Crown Victoria
Old Jan 27, 2021 | 08:25 PM
Tobin Vice's Avatar
Default 2001 Crown Victoria
I'm having a spark plug coil issue. I change a coil pack every 3 months. The last one was on cylinder #3. I have always brought it to the same mechanic. They clear the check engine light and replace the ignition coil. I recently had the mechanic change a heater core and they replaced the intake manifold.This miss fire is at 40 mph, and in over drive at low rpms. The car still smokes the tires at take off. Also it seems to be idling fine. Any suggestions?
Old Jan 28, 2021 | 03:47 AM
raski's Avatar
Misfires often occur when the engine is under load. If your mechanic is using aftermarket ignition parts, I would insist on Motorcraft ones the next time you have an issue.
Old Jan 28, 2021 | 05:01 AM
Tobin Vice's Avatar
Thank you Sir
Scott Desjardins
Aug 16, 2017 11:46 PM
Sanddoc
Jul 1, 2017 05:49 PM
norbie
May 20, 2010 01:58 PM
Another Device
Feb 16, 2009 09:41 AM
Killer Cougar
Jun 4, 2007 06:35 AM
