2003 misfire / rough idle
Old Apr 7, 2025 | 01:22 PM
johnjn6789's Avatar
Default 2003 misfire / rough idle
I had a misfire code come up on cylinder 8. i had mechanic replace all 8 plugs and the coil pack on cylinder 8. cleared the code but runs rough now, hard shudder at 40 mph. burns about a gallon of gas per 5 miles. mechanic said bad map sensor. replaced that but no change. still no codes coming up. what next??
Old Apr 7, 2025 | 01:43 PM
As you know all vehicles are not the same, so how about a little more info ?
What engine in your vehicle and miles.
Can you have someone check for codes BEFORE shutting off engine?
Could you mean MAF sensor ? Big difference between MAF and MAP sensor..
Jhawker23
Aug 28, 2022 04:11 PM
TorchHypnosis
Sep 26, 2021 04:01 PM
djr32978
Mar 13, 2016 04:06 PM
Dundee
Jan 28, 2009 10:35 PM
miknwv
Sep 3, 2006 04:16 AM
