2005 p71 transmission
Old Jan 30, 2020 | 10:11 PM
Darn's Avatar
Default 2005 p71 transmission
I have a 2005 Crown Vic P71. My transmission shutters between 3rd and over drive. If I hit the gas it kicks down and stops until back in over drive I'm try to figure out what transmition this is. What I have found on the Internet is running me in circles. One site says there are 12 different versions and another says their is only one I was told I could identify it by the VIN # But I don't have that . I did a full chassis swap with a 65 F100. When I scraped the body I had to give the title I'm going over my options as to maybe repair myself or have it rebuilt Any help would be awesome
Old Jan 30, 2020 | 11:23 PM
Welcome to the site..
Would be a 4R75E. How many miles on the unit?
Sounds like your condition is torque converter shudder. The converter clutch slipping on the OD lockup.
when was the last time the fluid was changed? Sometimes a fluid change will correct the condition, or lessen the shudder if higher mileage..
Old Jan 31, 2020 | 06:25 AM
Darn's Avatar
Unsure if the fluid has been changed. It has 130k on it. I’ll give that a try. I was using as my daily driver but it’s getting worse and it’s super annoying. I did put shutter stop in it, like magic it worked great for three or four days.
Old Aug 19, 2020 | 09:43 AM
giddyup306's Avatar
When it acts up hit the OD off button and see if it kicks down correctly. Without me seeing it, I'd bet your OD band is going south.
Also a fluid change more than likely won't do anything. That's a PM. Once the damage is done, It's done. I've done loads of trans flushes, and customers think it will magically fix the problem. You can try some Lucas Trans Stop Slip. If it's not too far gone, it can help, but no guarantees.
Old Aug 19, 2020 | 11:43 AM
Darn's Avatar
I would turn the over drive off and it would work great. I did the fluid change with no signs of change directly after. But the more I drove it the better it got. Now months later is working great with no issues. I usually see other people do the easy stuff and it fixes it. This is a first for me. I’m guessing the car sat before I bought it and it needed to be driven to get all the parts moving like their supposed to.
JFStoltz
Apr 18, 2018 07:10 PM
TTEUVKY
Feb 10, 2018 01:42 PM
grandmarq
Nov 28, 2011 06:02 PM
jsupafly
Aug 2, 2010 08:44 PM
semperfi64
Aug 7, 2005 11:54 AM
