Directional 2007 GV
Old Aug 19, 2008 | 02:45 PM
jimdartt's Avatar
Default Directional 2007 GV
What is the best way to remove and replace the right side directional/side light in the front?
Thanks,
Jim
Old Aug 19, 2008 | 02:51 PM
jimdartt's Avatar
Default RE: Directional 2007 Crown Victoria
I met CV
Old Aug 19, 2008 | 06:31 PM
way2old's Avatar
Raise the hood and remove the plastic raqdiator cover. There is an 11mm nut,(a 7/17 will work) that needs to be removed. It is down behind the headlight area. After you get that removed, there is a screw on the back area of the lens. Remove the screw and then remove the lens. Remove bulb.
rbrothers
Aug 17, 2014 02:34 PM
1k2k3k
Sep 24, 2011 10:01 PM
tmontemayer
Sep 4, 2011 01:56 PM
ivanyurkinoff
Apr 22, 2008 09:38 PM
bingermann
Oct 31, 2005 01:36 PM
