Electrical Issue
Old Dec 14, 2008 | 10:19 AM
adjnyctek's Avatar
Default Electrical Issue
Hello All
Am new to the Forum.
I have a 99 CV and this last few days the anolog and gages fuse blows when I shift to Drive. Any one has an solution.
Thanks
Angel
NYC
Old Dec 14, 2008 | 12:37 PM
way2old's Avatar
Default RE: Electrical Issue
More than likely the wires that run through the shifter are rubbing and causing a short. Remove the steering column trim and look at the wiring really close.
Old Dec 14, 2008 | 07:01 PM
adjnyctek's Avatar
I thank you for taking time to RE my message. I'lldo as you suggested, do you have a specifit area?
I mention is only when I shift to drive. FUSE #13 on the fuse box isfor theWarning Lamps, Analog Cluster Gauges and Indicators, Electronic Automatic Transmission andLighting Control Module can it be that its has something to do with the transmission? am a bit worrie I have a 755 mile trip from NYC to Detroit on the 23rd.
Old Dec 14, 2008 | 07:23 PM
way2old's Avatar
When you get the covers off the steering column and see the wires, you will see a smalol place where the wires are nicked. It will be close to the top near where they come out of the shifter. You can repair it with electrical tape. Tou just need to keep it from rubbing on metal. I don't think it is anything any more serious than that wire.
willijimon
Oct 21, 2018 08:07 PM
colt_13f
Jan 2, 2008 12:03 PM
bgardner
Dec 9, 2007 06:50 PM
rgbutler
Sep 11, 2007 07:05 PM
JimmyGInOKC
Jul 26, 2007 06:25 PM
