Forscan- license issue ?
Old Apr 14, 2026 | 09:45 PM
Vaclav's Avatar
Default Forscan- license issue ?
I had attempted to make my Crown Vic P71B to be keyless entry. Watched videos and purchased bbfly Pro obd II scanner. From Amazon. Product is bbfly:BF32302 with USB adapter It does has MS-CAN or HS-CAN switch.
I had downloaded all drivers and verified that they are downloaded .Drivers are up to date, I believe that I had downloaded all other necessary software as well.
I had issues understanding some of the terms- HARDWARE ID- what is that? THIS CODE PULLED AUTOMATICATICALLY WHEN I PLUGGED the unit in. 1K9yDQVSPhq7795q Is that what this code is supposed to look like?
ENTER ACTIVATION KEY? _Where do I get that? And finally, LOAD LICENSE KEY.
I can connect to the car, using my laptop. It shows different car- 2007 with different last 5 digits of VIN number. When I tried to change it, it wont let me. It just tells me to turn key on off position. Then it reads same - wrong - Vin number and make and model, which I do not have. I had double checked that twice. (looking at the the VIN through front window)
I can connect to the car with my laptop using usb to bbfly pro. Unable to use all functions. The fake / strange VIN. (this is wrong to start with ! ) Just can not go to activate DDM remote keyless entry. ( I have 2 new remotes in hand)
Thank You for viewing/ advise in advance.
sincerely, Vaclav Macek
service technician, Securitas
Old Apr 18, 2026 | 11:00 AM
Vaclav's Avatar
Here is an update. I ended up buying actual 1 year license (20.80$) and I was able to program keyless entry remotes. DDM code to use is A915 on the 8th line of menu. It worked .
As for Vin number identifying -showing wrong car, I just ignored that as well. PCM may had been changed previously.
Hope this helps someone.
JacobMyler
Dec 4, 2022 08:22 PM
willp1974
Jul 18, 2021 05:05 PM
jhuntco
Sep 4, 2009 03:01 PM
gametime2387
Apr 26, 2008 11:53 PM
chemoman
Oct 16, 2007 07:08 PM
